nephew uncle and a old go-cart
ice
Hello to all. My nephew was given a free go-cart. and old uncle here is given the chore of getting it running, So the Briggs and Stratton will not start. I looked into it and found that it had no spark. I disconnected the black kill switch wire and now have spark. I would like to order a new wire. These are the only numbers I can find.
ps. I also have a lawnmower that needs a new kill switch. I would like to order both kill switch's at once and from the same place. Any help would be appreciatedDSCN2545.jpgDSCN2544.jpg.
Unless the wire has a bare spot that is touching metal it is not your problem. The switch is likely faulty.
Hi Romore , can you send me a pic of what the switch looks like a part number, please? Thank you
Follow the black kill wire and you should find the switch...
And can't get a part number without the engines model number
