Throttle wont idle down
jakesmurray
The other day when I finished mowing, I went to throttle the engine down to shut it off, and nothing happened. How do I adjust the throttle linkage? It is a Briggs 12.5 hp i/c quiet engine. Thanks
if the throttle link is fine then check the spring this usually happens over a period of time but is worth a try:smile:
Ok, just solved the problem... It wasn't actually the throttle cable, it was that the carb just needed adjusted. It wasn't allowing the throttle to change the RPMs. Now it runs great and idles down perfectly. Thanks for your help guys!
