How to install tension spring on mtd tractor
BJO14
Hi tension spring broke, need to know by picture how/where to install. Model 13bc762f000, serial, 1b012b30041, 2014 model, its #22 on diagram. Not sure where to upload pics.
Spring 22 is the brake / belt release spring.
It goes into a hole in the plate # 2 and pulls forward.
You should see wear marks in the paint
The spring is stretched about 1" to 2" when the PTO is off so use a bit of string stretched from the hole in plate 2 to locate the mounting point, usually a hole as well in the deck.
Thank you, will have my husband take a look at it, and see if this helps him out. May be back!
