Leave it till you have the time to put in.
It is not like the tool will blow up, it is just annoying.
A small leak at the impulse line, the coil air gap being slightly too big, all of these make little difference to the high speed running will make the idle erratic.
It is one of those things that is oft diagnosed by ear.
A plug that is slightly out of size.
Usually you can hear if it is stalling out rich or lean.
The easiest work around is to richen the L to the point that it hangs when you accelerate.
Now it could be just the H & L jets being out of adjustment as mentioned before there are times I have needed to adjust the needles through 4 or more cycles before I get it right.
It just depends where the cross over L to H is.
I have fooled myself on more than one occasion and had a carb running on just the H needle.
With older carbs it is easy because the adjustment is coarse so if going from rich stall to lean stall was more than 3/4 of a turn you knew you had a problem
1) needle or jet damaged
2) running on the other jet
The new EPA compliant ones are harder because the taper is shallower so 2.5 turns of them is 1 turn of the old ones.
