my cub won't start
451johnny
my cub AGS 2160 won't start it only start when I use starter fluid and that only for a second or so..I checked the fuel pump and the pump works..?? appreciate any help....johnny
cpurvis
If you can start it with starter fluid and keep it running with intermittent sprays of starter fluid, your engine is not getting any fuel from the carburetor.
451johnny
but I disconnected the hose from the pump and the pump shoot out gas..?? would the carbruator need cleaning then ??
Scrubcadet10
Moderator
Staff member
Yep, sounds like carb cleaning time!
I presume an AGS 2160 is a ride on with a 21 Hp & a 60" cut..
In that case it has a cut off solenoin under the carb.
If the plunger does not retract when the ignition is turned on then the engine ( engine not carb ) can not get any fuel.
451johnny
yes I remember doing that with another tractor ..I'll definitely try that first..thanks buddy
cpurvis
No, it's a 16 hp 2000 Series. Doubt if it has a solenoid; my 2140 doesn't.
451johnny
it's a 16hp and I just got now2 cleaning the carbruerator and she still won't start it just cranks..?? at a lost now
