CajunMan89
- Feb 28, 2014
- Threads
- 22
- 83
You're welcome! There are youtube videos out there, but none that I like from a professional standpoint. I will include a link at the bottom of a video that will get you on the right track. The guy in the video does it correctly, but doesn't explain the procedure thoroughly enough for someone just learning to do it.
To adjust the deck is simple:
1. Buy a deck leveling tool as referenced in the video. They are fairly cheap. (There are guys out there that use pieces of wood and measure off the deck shell. Do not do this! It is not accurate!)
2. Set your tire pressures. 12-14psi in front, 10-12psi in rear.
3. Park machine on a level surface and set your lift height handle at the 3 position.
4. Check your side to side level. Reach under the deck and turn the blade until it is pointing side to side. Using the deck leveling tool, measure from the ground to the outermost blade tip. Do this for the right and left blade. The measurement should be 3 inches, plus or minus 1/16th inch. (the naked eye won't be able to tell if you're off by 1/16th inch)
5. Locate the adjusters mentioned in the video, and adjust your deck up to 3 inches.
6. For the front to back level, we will just use the right blade since we can access it easier. Point the right blade front to back. Adjust the front link as shown in the video to set your front to back level. You will want the measurement at the front tip to be 1/8-1/4 inch LOWER than the rear tip as explained in the video. This ensures the front tip does all the work as the blade is spinning. If it were perfectly level, both tips would be cutting, thus creating twice the load and overworking the machine.
https://youtu.be/pigBRailqTY
Awesome video! Yes, I've seen some with people using wood, never thought that was a good idea!
I figure that this would be the best price for a level, since my local dealer would probably be higher. https://www.ebay.com/itm/NEW-JOHN-D...924603?hash=item48a4d2d03b:g:mpcAAOSwEZdaCwu7
If this is the correct level, I'll post back as soon as it comes in and I get it leveled.
Thanks again!
![20190926_182132[1].jpg 20190926_182132[1].jpg](https://www.lawnmowerforum.com/data/attachments/27/27080-e6c118183df8fb32c0da17d3d7a1d931.jpg)
