Greatwhitewing
Long saga with starting problems. See attachment for motor nameplate data. I have thoroughly cleaned ground and power connections several times. This has been going on for years now and I have read just about everything I could find with google.
My Kohler has hydraulic lifters (pushrods). I read un-adjusted valves can cause decompression mechanism not to work. Can find NO info for adjusting hydraulic lifters so I don't know if this is a problem or not.
Symtons- won't start unless a car is jumping the battery and car running. Battery packs for cars won't work and won't start unless the car is running. I know, far too much power but it's the only way to get it started and grass doesn't wait.
I have replaced battery, starter motor, solenoid and ignition switch. Solenoid and battery over the winter, Starter motor and ignition switch just now. After replacing solenoids and battery over the winter it started about 5 times normally then returned to needing a running car jump after that.
My plan is to try one more starter solenoid and then push it over a cliff unless I can get some suggestions I haven't considered yet.
