patricksween
I run an F935 with 72" Commercial deck, mowing about 16 acres. The gearbox on the deck just failed, not sure how or why, but need advice. From what I can see online, new gearboxes are upwards of $1000 if you can find one, even used start at around $400. This is an older mower, so only probably worth around $1500-2000 if it was all working. I could try to swap the whole deck, but the older decks are also not super common and may also have gearbox or spindle problems that I don't want to deal with. Are there other options for the gearboxes, or are there other decks that would be compatible with the F935? Some of the newer decks, like the 7-Iron series seem to be more common but not sure they'd be compatible. In any case, it's not worth it to put $1000s in to this mower, so looking for reasonable fixes to get it running until I can upgrade in a season or so. Thanks for any advice.
Patrick
Patrick
