my yth2042 does not move forward or reverse
451johnny
I have a yth 2042 that doesn't move forward or reverse when I activate the lever I'm yet to look at the connections to the lever and was hoping someone out there can tell me what to look out for and how to tackle it'''thanks in advance johnny
two usual cayses
1 ) drive belt is broken or off a pulley
Is the brake pedal higher than usual ?
2) brake itself is locked on
Can you push the mower without the wheels locking ?
two usual cayses
you mean pushing it while the brakes are applied ?? not sure but I don't think so gonna have to try it tomorrow ??
No pushing it with the brake off.
If the pedal is higher than usual then you have a belt failure / pulley failure.
So it will be a case of removing the deck then getting underneath
I block off the fuel cap using some cling wrap, remove the battery then stand the mower up vertical on it's rear wheels.
This gives clean access to the belt & the clutch pulleys.
Even better all of the crud under there will drop to the floor rather than in your face.
yes I could push it..and I'll be checking out and doing what you said I'll let to know tomorrow ...thanks so much I really appreciate it...johnny
Also might want to check the hydro release in the back just to make sure it is engaged or in drive mode or free wheel.
