KentuckyTim
- Sep 2, 2019
- 3
Hello All! I have a Gravely 252Z with a 25hp Kawasaki engine. The issue is that the engine runs fine until the mower is engaged, and then the engine will surge and slow, repeatedly; if I don't disengage the mower, the engine will eventually die. If I disengage the mower, the engine will continue to surge and slow for several minutes before eventually running normally. Then, if I engage the mower, it will run for just a little while before the slow/surge cycle repeats. I've been battling this all summer, trying several things to repair it. There is no vacuum in the fuel tanks. So far, I have replaced: the carburetor, the fuel lines, the fuel switch (there are two tanks), the coils, the spark plugs, and the fuel filter. Nothing has fixed it. What's odd is that it only starts surging/slowing when the mower is engaged, but also continues to do it for several minutes after disengaging the mower until it finally settles down. I am at my wits end. Anybody have any suggestions (other than to buy a new lawnmower)?
