Try spraying some down the plug hole, and reinstall the plug, if it fires it's probably a valve/timing or spark issue. (Let a expert confirm that)
If it won't fire normally, backfire through the carb or backfire through the muffler, then I doubt you have a good spark. Bad timing won't stop ignition; bad timing only fires the fuel mixture at the wrong time.No, won't fire at all.
Ok, if it's the spark, what will fix that? New coil? Magneto?
How do you know this?I filled the tank with gasoline and tried to crank it; nothing. So I figured maybe trash was in the carburetor. Tore into the breather and discovered the filter had been leaking and the carburetor was full of dirt. I removed the carburetor, cleaned it meticulously with carb cleaner, toothbrush, air and rebuilt it with new gaskets, float valve and a new solenoid. Cleaned out the breather housing and the intake manifold, installed new fuel lines, new filter, new fuel pump, new plugs and checked them for spark. The plugs are sparking and the clean carburetor is getting fresh gas but she still won't start.
Can you measure the resistance of each coil?
