- Sep 24, 2017
- Threads
- 250
- 6,441
I don't know if any of the John Deere tractor you are looking for has the Kawasaki FD590, that Kawasaki engine is notorious for breaking the plastic Cam shaft around 900 hrs. I believe. Just my :2cents:
So far all the Kaw's I'm looking at are FC420's 540's ond the 501 watercooled
Side by side in great condition, I would pick the 325 over the X500 in a heartbeat, both from a reliability standpoint and also from a technician (DIY) standpoint.
The 325 is also more comfortable to ride on and has a lower center of gravity.
The X series seats are uncomfortable and make you sit higher. (I have a bad lower back)
The mower deck can be removed quicker from a 325 also.
Overall, the 325 is a better built machine when directly compared to the X500.
Don't read me wrong, the X series are great tractors, but this is just my preference.
I haven't seen any complaints about X500 reliability. You probably know something I don't, but the X500 is looking good to me. I didn't know the 325 has a lower center of gravity. That may matter to some folks, but not me. I pretty much stay off the slopes. The traction assist on the X500 was a strong selling point for me, plus it has 1/3 more horsepower which I may not need, but I sure like it.
... I'm looking for a 48-54" deck model that has an engine that will provide long life as I have around sunny 4 acres that I have to my in a location that downtime is a real killer. I can easily find 6 different JD lines that fit the bill Manf between mid 80's and late 90's that fall in my price range, which is at the ragged bloody edge of a reasonable amt for such a mower $500-700 I'm hoping for a little help sorting things out :-D
Lots of good info there dekeda,
I'm staying away from the pre late 80's models. I have had two Kohler K series motors go to that great yard in the sky this year. They both ran perfectly with no loss of oil and a good looking plug right up the second they died, one locked up and one threw a rod. I think it's asking a little much of a 35yr old air cooled engine no mattter how well constructed.
I don't think I'd want to put a 48" deck on my 175 The 38" with a mulching plate in the heavy/thick grass is enough for 14HP.
I looked at a LT180 last night. Lighter duty deck and frame than the 275 but it looks to be a good mower....
I have 2 properties 200 miles apart and would rather not shuttle the 175 back and forth plus the 38" deck is a little small for 4 acres The LT is being sold by the original owner and is a 2004 model. He mowed about 1.5 acres of flat land changed the oil every spring and has no attachments except the deck. Asking Price is $600 If I can get 5 years of good service without a major problem I'll be very happy with it.
