turnipgreens
- Aug 15, 2019
- Threads
- 1
- 5
Briggs & Stratton 128M02-0133-F1 DOM Apr 2013
190 cc 7.25 on a 22" walk behind mower
Howdy, I need some help please.
I have a Toro Brigss & stratton that I bought new, have always ran non ethanol fuel, has dependably started and ran for years until now. If I spray some carb cleaner in the it will try to start/run for about 2 seconds and stops. I do spray it off with water after each use, always have tilted it carb side up.
Checked carb fuel bowl (clean, no water) and contained fuel , float moves, and jet was clear but ran wire through to confirm,
Auto choke assembly and springs are in place,
Replaced the dirty spark plug with same new Champion RJ19LM,
replaced dirty air filter (it wasn't fuel or oil soaked),
replaced Ignition coil with new B&S,
flywheel key is intact,
All that and still the same issue.
Does this machine have a hidden fuel filter or something, starving the fuel intake?
Thanks!
Thanks!
