bull nutria
- Jul 28, 2019
- 4
I purchased a used low hours Timecutter. I noticed that the left blade is cutting at least 1/2 inch lower than the right blade. I took the deck off inspected it. deck does not seem warped. however left blade rubs concrete and right side does not. there is a slight wobble in left the top pulley when turned by hand. no noticeable slack in the bearing on either spindle.
is it possible that the spindle in bent? blades don't seem bent, they are mating side by side on a level table. I inspected the deck hangers and they seemed to be correctly hanging.
Has anyone encountered this problem with a Timecutter?
the mower runs well and cuts well just very uneven. I adjusted the right/ left adjustment and it didn't help.
Bull
Bull
