philnotfil
Briggs and Stratton 122T02-0377-B2
Replaced gasket between air filter and carburetor and primer bulb. When I apply compressed air directly to the port on the carburetor it squirts gas through the nozzle in the carburetor, so the problem is upstream from there. The old gasket had a well defined channel for the path of the air from the primer bulb. New gasket does not. Do I need a different gasket? Do I just tighten the bolts more until it has a good seal?
Any suggestions here?
Thanks,
Phillip
Thanks,
Phillip
