briggs 24hp only runs with one plug removed
pinevilleoxbow
guys
looking for thoughts on my situation.
briggs 24hp platinum on a craftsman zero turn
randomly mower quits while cutting. 200hours on it.
i pull it back to the shop and do some quick checks.
determined that if i pull the right plug completely the motor will fire and run on the left cycylinder.
will not runn if the left plug is pulled and right plug is in
done a compression check and have both 150psi
swapped coils for the hell of it.
checked for spark and have spark on both sides.
have changed plugs
right side seems dry.
sprayed some started fluid in it just to try. no difference.
Fish
Remove the valve covers and take a peek...
Fish
You will likely find a loose pushrod.
pinevilleoxbow
baw, you were exactly right!
the bottom push rod was dislodged from the retainer.
i need to find a guide to reinstall. and i guess go buy some feel guages
thanks
pinevilleoxbow
PTmowerMech
A tick? The valve cap was still on there when you adjusted it, right?
