Tree_farmer2
I have a John Deere STX38. The front wheels aren’t parallel, the left one is going left, when the right one is pointed straight ahead.
There seems to be no way to adjust the toe-in on this mower.
I found the technical manual, but it seems to be saying that you have to order a part to adjust it. Says “If toe-in is NOT within specification, order and install adjustable tie rod service kit.”
Has anyone figured out a way to adjust toe-in on this mower?
Do you know the part number for the adjustable tie rod service kit?
Or is there an other/cheaper part I could buy?
Thank you!
Thank you!
