prometheis_78063
- Jul 28, 2019
- 7
I just replaced my entire cutting deck, (2)spindles, (2)idler pulleys, brake puck/pads and brake hardware, belt and blades. When I reconnected the deck, the motor starts w/no issues, but when I engage the PTO lever on the rear right hand fender, the blades do not engage.
The old belt had slack, the new belt has less slack but still has slack. I have the shop manual (all 186 pages) and from what I've read, I have a mechanical (versus electrical) PTO engagement system. The manual shows the beltway for every deck except mine which is a "S" deck, but believe I have it threaded correctly.
After researching the web I tested the PTO switch by trying to start the engine while sitting on the machine with the PTO engaged and engine wouldn't turnover/start, but starts right up if the PTO lever is in the off position. The PTO cable is tight and in good repair. If I have to put it in the shop, I also have to pay for pickup and delivery to San Antonio 35mi away.
On a footnote there is good tension on the PTO lever. Also when I reconnected rear left and right sides of the deck I installed the "U" brackets on the deck to the outside of the pull-down lever and rod (with the cotter pin) to the inside of the mower (again no photos of the rear deck installation)
I would appreciate any inputs or suggestions you may have
700 series shop manual - http://service.mtdproducts.com/Training_Education/769_06667_700_series_riders.pdf
