SF_LawnWorld
- Jul 19, 2019
- 5
Hello-- Noob Here---
Just moved from California to Georgia, and have a bit of lawn to mow. Bought the Hustler Fastrak 60". On the first mow, it took from 9:30 am to 5:30 pm to finish the job. I was pretty happy with the result, setting the mow height at 3.5". However, it may need to be set lower because a week later, it was looking like it needed another go.
My question to the more experienced guys that know these mowers is, how hard can you run them. Sometime the mulch will build up pretty good, and I will slow down quite a bit so as not to bog the engine down too much. Some of the ground is covered in very thick and tall lake tule reeds and such. But I also have a LOT of grass and the mower will run for several hours at a time, including some pretty steep mounds.
Are these units tough enough to run hard?
