ScottsOwner2046
- Jul 4, 2019
- 3
I have a Scott's 2046 Briggs&Stratton. Will crank fine, and idle fine, then when engaging the blades it starts to act as if I have pulled choke lever up, and will eventually die. I have to lower RPMs, start blades, then slowly increase engine RPMs. If I encounter tough grass or a small hill, engine begins to choke out again. I have installed new deck blade spindles, rebuilt carb, has relatively new fuel pump, run ethanol free gas. Has been doing this for 6 or more months!
Please help.
Jim
Please help.
Jim
