Finally got to take some pics. Because i want to be able to use the winch at both ends, mounting it and running wires from the battery in a permanent way was not a option and this is what i came up with. I also rigged up a place for a solid rod i can drive in the ground for the winch cable and a sledge hammer in case there is no tree or fence post near by to wrap the winch cable around. Things are starting to dry out now but i know for sure i'll be using the winch sooner or later. Hope it help others with the same getting stuck issue.
