My 14 year old son started a small mowing biz this summer (20 properties), and we bought a Z655 24 HP Kawasaki, zero turn, used, with 250 hours. It normally runs good, and is a clean mower. He mows about 2-4 hours at a time, and about other every time he mows, he will bring it home with this problem. He will mow, and it will loose power, and die, and the only way to restart it is to choke it and run it on choke for a bit, and it will drive without the blades going, but when he hits the PTO again, it looses power again and dies. After letting it sit a few hours the problem goes away for a while. Some days it does this, and some times he can mow 4 hours straight with no issues. He thinks it might happen more often when its hotter out, or when putting a bigger load (tall grass) on the mower.
I'm betting its a fuel delivery issue, I've checked the gas cap for a vacuum when this happens (nope), the fuel filter, and briefly the fuel pickup in the tank for splits or leaking around the top. I have also removed the carb and cleaned it twice very thoroughly, with jet probes and cleaner, and never find obstructions. I am so tired of this mower at this point. I think I will order a new fuel pickup, new fuel lines, filter, and fuel pump, and see what we come up with. Any suggestions?
