New member 1st post w/questions and thanks
kge4166
Hello all. I’m a new member here and have been reading for a while using the knowledge here to repair my Honda mower. My now retired mower is a HR194 px. I trashed picked it ~25 years ago and it has served me well. The roto-stop has damage to the cable attachment plus the underside of the deck is pretty beat up. Time to move on.
My ‘new’ mower is a Harmony 215. Came with the bbc not installed and a bad bearing on the blade holder. Paid $75 for the mower and $20 for the bearing. Got that sorted and all is well. This is where the thanks are due. There’s no way I’m getting this back together and running well without this forum. So thank you to all who post and share knowledge here.
My question is I wish to replace all four wheels. I see many options and part numbers but I’m not sure of the correct number. The model tag on this mower is missing.
Thanks again, Keith
How about the old fashioned way? Take a wheel with you to a place that sells mower parts and see if they can match it up for you.
I have Harmony HR215 SX,transmission is broke but engine and all 4 wheel are very good condition ,I also have the plug for mulching .If you live in Houston I sell it for $50 .IMG_0366.jpg
Any idea what failed in the trans? The SX tranny really is pretty caveman simple ...
Were I coming to Houston any time soon, I'd grab that in a second (in the Dallas area . . . ).
Oh, and how's the engine?
- Tim
Harmoney model use belt for transmission,it"s not good as older model that use PTO shaft .The sleeve bearing that hold pully shaft complete worn out,I have a new bearing but its too loose as block worn out also .Engine is in good shape .Im sure have enough to use for the rest of my life
@tranchinh An HR215SX is a shaft driven, 3 speed geared transmission with a GXV140 and blade clutch . . . if that's not what you have, then that's not the right model number. The HR215 is Masters series, not Harmony . . . and appears to be what the two on the right in your photo are . . .
Please clarify what you offered for $50 . . . if it really is an HR215SX, well, the drive is boring but not that bad . . .
