The Brain
- Jun 26, 2019
- 77
hello I think the drive belt is worn and stretched where the mower isn't fast moving at all.
usually mow every 2 weeks previous mow seamed OK.
I was able to mow the back yard yesterday however it was very slow.
notice the huge amount of slack in belt this slack is reduced when cutter is engaged but there's still way to much slack.
can I loosen the frames collar and slide the frame forward for desired belt tension or is the belt stretched to much?
I observed a loose spring in last image.
the mower seriel # 2012912220 it's a 2006 rear engine 12.5 horse power riding mower I would like a new belt how long is it ?
I think it's a 28" deck
any tips on the belt swap like where to obtain a decent belt I'm thinking it's a 72"
Snapper Belt 37X72MA and install tips is appreciated
TB
TB
