Which sparkplug, 190cc came without plug
Gta_g20
So I have a lawnmower that I got. No spark plug in it. Put in a sparkplug from another mower and it runs but idle is hunting and backfires. How can I find the correct plug?
Definitely needs a carb clean and check the gaskets for any air leaking.....also check the gas. It may have some water in it. Better to just dump it out and start wtih a known fresh tank full if you are not sure.
