Good morning, Walt!
Magnet says: no attraction at all! - funny how sometimes the simplest things fail to spring to mind, tststsss ;o)
Right hand cylinder bore looks quite nice, will see other side later today.
Perhaps I'll be lucky for a while, because we found tons of reasons why this engine wasn't able to run for quite some time:
- the man we bought it from, how can I say this, he was not in the workgroup that invented the deep dish, if you understand
- - the magnetron was mounted the wrong way and he was wondering why he didn't get spark
- - he told us about his last mowing which ended with misfirings and we found a destroyed sparkplugthread with a loose plug in it - which I fixed today
- - the sparkplugs in it had way too low a heat value which must have led to glow-ignition
- - half of the interior of the fuelpump was missing
- - and on and on it goes
Every screw we loosen a new surprise - stuff for endless joy. I think that this engine wasn't running much in the last dozens of years, should be pretty much life left in it I hope
Measurments will show.
Thank you all,
greets
Franz
