old craftsman tiller
deano77
need to know if anyone has an idea where to get an emulsion tube for a downdraft carb tiller is craftsman 8 hp model917.295582 engine is briggs 8 hp 190402 or a replacement carb and manifold
deano77
i got type 085101 or l01 serial17859 and the tiller is craftsman model917.295582 serial17859
deano77
and that was an updraft not downdraft i should have said
If you are talking about the tube going from the valve cover to the back of the air cleaner tube it is part number 67068. Should be able to order one through any good repair shop.
deano77
no i am talking about the emulsion tube which seems to also be the main jet it is the seat for the fuel adjustmenr the tube screws in and fits in a hole on theother side of the air barrel then the fuel adjustment screws into that it was bent and when i straightened it it broke but now i think i will solder it because i have a drill bit that fits and if solder gets in the tube i can drill it out
deano77
iwill post pics as soon as i figure out how
Romore
That is not a valid type number, can you check it and get back to us?
You mean the main nozzle which is part number 390395, but is no longer available. It is also included in the repair kit part number 295938, which is also no longer available. Lucky both are still available on the Internet. Just type in the part number in google search and you will find them. I recommend get the full repair kit, with the age of that engine you will need the gasket. This manual might also help. https://drive.google.com/file/d/0B6NaqjIxWV1ycG8wd0s3Z2Q2X00/view
