I replaced the 2 counterweight links and camshaft . One question I hope someone can help me with. I had all the motor parts on my buddies workbench and not sure I picked these pieces up or if they belong to my motor. I’m sure the last pic longer pin shaped like a “D” is part of the decompression cam. The other 2 are roughly same size, one is a solid pin the other is hollow with a slit on side. Any help appreciated, want to make sure before I put back on tractor and fire it up. I’m not sure if they are part of my motor or where they go if they are, when I opened motor everything was in pieces.
