Used mower. The left wheel is a little more worse camber than the right.
It doesn't appear that the drag links or spindles are bent. I did notice the spindles move around in the axle much like a worn ball joint on a car. I am working off of page 12 of this parts list.
http://service.webec.husqvarna.net/...nNAes/HUSI2012_NAenNAes_LGT2654_581540027.pdf
I ordered a pair of #7 and #8. Gee, they are only washers.
When I took the spindle off, I found a plastic (PLASTIC?!?) bushing at the top of #2, front axle assembly not in the IPL.
I ordered these. Are these correct? They don't really match per picture but the part number is right.
https://www.ebay.com/itm/Set-of-4-B...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Are there metal (perhaps brass) replacements?
On the bottom of the axle it appears that there is a bushing that goes into the axle that is worn, also does not appear to be in the IPL.
Here's a pic.
Does this come out? I was thinking of driving it out from the top and putting another in.
If it does come out, is this the replacement?
https://www.allmowerspares.com.au/husqvarna-front-wheel-bush-532-12-49-59.html
Or am I looking at replacing the axle assembly?
Any other tips to upgrade the steering on this thing?
Thanks so much for your help!
Here's a pic.
