I have about 5 hours on mine and am very impressed how well that little 159CC motor runs. I think I may have stalled it two times total, it has enough power and I too give it 5 stars. Picked mine up at Tractor Supply for $300 on line.
I purchased one, but it won't start when hot.
What gas are you using?
Just regular pump gas with 10 % ethanol. Sounds like a choke issue.
Mine starts on the first or second pull.
Well, This is the first machine I,ve owned that starts on the first pull every time. Warm or Cold. from the very first fill up of gas. It says it has a Cub engine but from my research it looks like a Honda engine.
I really like my ST100, but wanted a third wheel for more stability. The conversion kit on line was too spendy, and I thought I could do better. The attached photos show an arm mounted 5" swivel caster which doesn't interfere with the trimmer. Just an idea...The engine is a Chinese copy of Honda, but seems to be just as reliable. I believe it uses an iron sleeve in the cylinder unlike Honda which is not sleeved.
