lawntender
- Apr 25, 2019
- 12
I couldn't get my Toro Personal Pace to start. Had weak spark so put on new coil. Has real good spark now. Compression tested and have 0 compression. Pulled off head and the top valve as you look head on at the mower has the bottom part of the valve seat has worked itself out about maybe 1/32" to 1/16" out. I know how to do the outside trouble shooting stuff ok, but once I pull the head I'm lost about what to do. Any advice would be appreciated. I really like this mower and wanna save it if I can. I bought a new 22" recycler with the Honda, but I really want to also want to fix the personal pace. The valve that won't seat is real sooty and top of piston is pretty carboned up. Bottom valve is a little gray but seems to seat good and work ok.
