Crabby Grass
Just a heads up regarding v twin engines.
I had a Craftsman mower with a briggs and stratton v twin that developed a sticky valve. After much consternation and replacing valve push rods I discovered the problem by removing the shroud, That the problem was caused by the cylinder overheating. And the reason it was overheating was that a mouse (or something) had built a nest that resulted in the cylinder fins being caked in mud. I cleaned it and the problem never came back.
So, I had a fuel problem with my year old Bad Boy with a Kohler V Twin and thought i should check under the shrowd. Surprise, a mouse had created a nest next to one of the cylinders. This time no mud, but it was crammed with grass and thread, and a couple of empty Hickory nut shells. This could have been disastrous.
Just a heads up that if you live in a rural area you may want to check under the cooling shroud a couple of times a year.
BTW, One year a bunny chewed through the fuel line on the Craftsman. Grrrr!
