Tannersnoo
- May 2, 2019
- 8
Good spark and new spark plug
New mechanical fuel pump
Fuel flows from tank to fuel pump but when I crank no fuel from pump to carb bowl.
Carb solenoid tested and works fine (retracts when key engaged when I ground it)
Cleaned carb thoroughly. Still no fuel.
One thing I noticed is one of the fuel pump mounting bolt holes is stripped so I’m not getting a good seal. Is it as simple as Helicoil the bolt hole and tightening the mounting bolts to spec?
Thanks. First post but I’ve learned a lot on this site. Tom
