Any of you guys install an LED light bar on your mower?
I put one on my truck recently and was blown away by how bright it is. Since it gets pretty hot here in the summer I try to mow closer to sunset but often run out of daylight before I get finished up. I have approximately 6 acres to mow.
I got a smaller version of the one I put on my truck off Amazon, it was only like $42 and it's IP68 waterproof (I use a leaf blower mostly to clean but still).
I also got a wiring harness install kit that comes with a rocker switch, and it fit (snugly) in the existing delete on the control panel!! I was really stunned it snapped right in.
The wiring is also super easy when using the harness, well it's easy anyway but it's basically plug and play with the harness. I mounted it on the front, and it is BRIGHT.
