nate81
- Aug 7, 2011
- 26
Check to see if throttle cable has slipped or governor spring has broke.
Take your hand and open the throttle linkage by hand and see if it revs then.
It may be running on 1 cylinder if I had it in my shop I bet I could find the problem in a few minutes just can't decide what is going on from the description.
exactly! I dont have a truck or trailer, and to have this mower moved would cost so much, and then labor...for someone to fix it in a matter of minutes.....i'm very confident this is a simple 5 minute fix!! I'm hoping I can get off of work a little early today and go poke around on it this afternoon, i'll let you guys know what happened if i can!
