Repairs fill transmission on LTX- 1045
qtrmile2
I have a club cadet LTX-1045. Bought it new about 3 years ago. Noticed today the right axle seal is leaking. Should be no problem replacing the seals but how do you refill the transmission.
Thanks for your help.
https://polr.partstree.com/v1/iplim...B0aW9ucyI7YToxOntzOjU6IndpZHRoIjtpOjEwMDA7fX0
See part #109. It's the spot where you add fluid. This task is so much easier with the transaxle out but you can use a funnel with a long hose. I believe the axle takes 20w50 oil if I am not mistaken. Make sure that everything and everywhere you are working is clean as a whistle. You do not want any contamination getting in.
Ok Thanks for your reply. I will check it out today to see if I can fill it without removing the trans.
