blenderbender
My TS460 concrete saw wouldn't idle, just ran at high speed no matter what. I played with jets and idle screw to no avail. Opted to replace carb as that seemed easiest. Bought a Chinese carb on ebay and it needed some mods before I could use it. Had to swap out choke shaft, throttle shaft, and top cover with the old. Installed and saw started right up but still runs full bore no matter what. I had pre-adjusted jets one turn each and backed off idle screw to maximum. I got no idea at this point. Any guesses? Thanks... Gary
