The Daily Yardman Thread
Roger B
Ya just can't beat having a large shop, a rotary hammer drill, a palm nailer and a big honkin' air compressor!
Not to mention a yella shirt and calves the size of melons! Yer life is GOOD!!
Rog
Boobala
Pumper54
Roger,
Thing that I see I left out of my story was the town two days to the setting sun was Nacogdoches and the one two days to the rising sun was Natchitoches. BUT I figure as you are a smart fellow who might have fingered that out. Hope you are able to get out on the boat today.
Tom
Ronno6
Re: Hi Old Silver.......(Buy Old Silver)
Ron,
You know for a 'busy' sort of guy, you still have far too much time on your hands! LOL
Rog
I spend my sleeping hours figgerin' how to do things the best and easiest way.
That frees up my waking hours for frivolities.............
Boobot nailed the Red Heads. I keep callin' them Red Hats............
As for the silver thing, I wish there was some way for me to tell people they are getting royally screwed if
they purchase those 1oz silver "bars"
Pumper54
Shifting gears here Gentlemen. I have also posted this over on the correct forum but figured with all the smart people that hang out here I might get an answer faster by also posting here:
Rebuilding a Sears mower engine Model 143.016000, Family YTPXS.1851BA which has been identified as a Tecumseh LEV 115-3600033D and need some help.
Have a really bad oil leak out of the crankshaft seal part 75 in diagram (https://www.searspartsdirect.com/model-number/143006700/0247/1503500.html) and am wonder if when I replace the seal is it set flush to the bottom of the case or is it set down inside the case? Does this make any sense? I have the manual and it says " CHECK TO
SEE IF THE SEAL IS RAISED OR RECESSED. WHEN INSTALLING A NEW OIL SEAL, TAP IT INTO POSITION GENTLY UNTIL IT IS SEATED INTO ITS BOSS. SOME SEALS ARE NOT POSITIONED FLUSH TO THE CYLINDER COVER. Sorry for all caps I am using cut and paste here. I trouble is the seal was replaced about a year ago and was flush to bottom of the case but I am now not sure if that is correct because to oil leakage started after the seal replacement.
I set the seal flush to the case but there is room to seat it a bit lower but I would rather not mess up the seal and gasket by installing it wrong. Any ideas would help.
Tom
tom3
Probably all the way in, but sometimes if the shaft it worn some, leaving it a bit off the bottom flange seat helps sealing. Probably doesn't make any difference.
Boobala
Seeing's as some are recessed, and some are flush (with reference to the cover) without the seal-protector & driver, I think I would opt for something a SLIGHT bit recessed, most important is surface condition of crank where the seal rides to make the seal, also being sure the seal "lip" has not "rolled over" .....
BlazNT
Total views 784
