Gravely Compact Pro 34-CE, diode function?
Clarettes
Hi,
for what purpose there are two diodes 8A, attached to the safety switches in my Gravely? Those seems to be the problem, that the Kawasaki engine does not start. If I connect them directly with a jumper, the engine starts fine.
The problem is, that I cannot find those diodes from France, where I am located...
Any ideas?
Regards from sunny Provence
Hello,
We can find any substitute diode for sure here in Europe :)
Can you post a picture of diode with all ref ? Or a schematic ?
Those diodes are useful for sure. Otherwise they would have just put a wire, it's cheaper :p
Hi,
Any ideas?
Cut the plastic off and you will find a diode , or pair of diodes.
They will have coloured bands on them that will tell you their values.
Then go to any electronics shop & replace .
Check them first.
Diodes are a bit on the delicate side.
Check them first.
Exactly what I have done. Gray-black color and 8A80 UMP on it does not give any hint which one would replace it. Neither does Google...
Totally don't understand what I can't find something that simple as a diode. Should be a custom marking, never see this. Even if it is UPM and not UMP, no luck.
We need to find a a diagram and estimate requirements of the diode, so you can replace it.
Is this your schematic ?
https://www.jackssmallengines.com/j...8-041000-049999-compact-pro-34/wiring-diagram
Is your diode in the middle, connected to a yellow/red and red/violet wires ?
