reddragon
THIS IS PRETTY CLOSE. ... Parts and Diagrams for Kawasaki Engines FD590V-AS05 4 Stroke Engine FD590V
I bought the gas at some old country store in the middle of nowhere, i wonder if it could be cheap gas? is it worth it to drain it all out, (full tank) and dispose of it and get new gas from elsewhere?
Drain the tank into a 5 gal. can put in new gas if it runs ok dump the gas, If it don't improve then use the gas rather than waste it.
You only need a gallon of fresh gas to try it bad gas will make it run really poor.
The plug gap would not be causing a lose in power if it is not missing it is fuel or weak spark, Plug would have to be wwaaaay off to be your problem.I will do be doing all of this on friday, one of these solutions is bound to cure my minor problem!
I was also thinking, could spark plug gap be the cause of power loss? I never set the gap, i just opened box and put it right into the machine...
If this started after you put in the fuel it may be your problem.
When you bought the fuel did you put any of it in your car and if so did it run ok.
