Repairs Toro timecutter model 74721 with kohler engine.
JerryL
The mower starts and runs great but after a few minutes it will die and then after a few minutes it will start back up, and sometimes it will continue to run for a period of time and then shut down. I check the fuel and add some and it will start and run for a while.The fuel tank is never empty. I have serviced the Kohler KT725 engine with a new air and fuel filter and changed the spark plugs and nothing changes. I have never seen the fuel tank empty and I am wondering if the kohler vacuum fuel pump does not have enough power to pick up from the fuel tank.
I need some help
Thanks
Jerry
https://kohlerpower.com/en/engines/manuals
click on above & enter KT725, scroll down page & your engine service manual will appear, click on service manual & see page 24 troubleshooting. i believe you have stale fuel in gas tank, add a quality brand fuel treatment & fresh high test gas, let us know how it goes. have you changed oil & filter recently? not mentioned in your post.
Sounds like you are starting and running your bowl dry. Then itis filling back up then it does it again. So plugged fuel line or fuel tank. Could also be a bad fuel pump.
You can rule out the tank & tank vent simply by removing the fuel line at the pump (from the tank).
Let gravity empty the tank into another container.
If it stops flowing you have an issue with the cap/tank, etc.
If it flows fully, move on to the fuel pump.
Coils do fail, often once hot. When the engine starts acting up, pull plug wires & test for spark (spare known good plug).
If no spark, you have a bad coil..
It's possible that your fuel tank isn't venting or that you have a bad ignition coil.
I have checked the vent and hose from the air cleaner and they are open and venting. The engine when it stops, stops immediately which doesn't seem to be a coil or it would misfire before it stopped.
Thank you for your suggestion.
Jerry.
I have changed the oil and oil filter and I use a 10-30W synthetic oil and I use stabul gas treatment.
With you letting us know it stops mediately kind of leads me to believe it's a safety switch. I would clean them with some electric contact cleaner. And then see if it continues to happen.
