Kohler Command Pro 25
Well, I guess I was so tickled it was starting good, I forgot to tell you what I did. I removed the solenoid and made a plate to cover the hole where it was. I installed a O"ring and put the plate in place and that did it. When I shut it off it stops like normal, no back fire. Works Good!
Thanks again, Gene
Thanks again, Gene
Excellent! Have fun!!
