mjwillyone
Friends,
I have a John Deere L120 that I purchased about 8 years ago from Home Depot. Today it suddenly stopped while cutting. The oil was fine. The air filter fine. The 20AMP fuse was blown by the battery. I replaced it and the engine turned a bit (not what I would call cranking) and then blew another fuse. I waited for about three hours, put in a new fuse, and tried again. The engine moved a bit, then I tried three more times. Then the fuse blew again.
I could easily turn the blade pulleys. I can also turn the large pulley directly under the engine.
Any ideas??
Thanks,
Mike
Any ideas??
Thanks,
Mike
