 - Nov 29, 2014
- Threads
 - 65
 - 24,995
Hi Folks.
So, I turned it around, but still doesn't work when i tighten the torx bolts. And, of course, they need to be tight.
Here's a video.
https://youtu.be/TmaoeTilfSE
I also got on live chat with Echo on Friday. They said:
Echo: The prevent plate should be flat. It looks like yours is bent.
Me: Is the prevent plate assembled in the appropriate direction and orientation?
Echo: Yes.
Echo: Yours has a curve to it. If you would like, I can email you a picture of what the plate should look like.
And they sent this photo:
http://echo-usa.custhelp.com/ci/inlineImage/get/20165/05407364fcc49cc4b70a5ec3a6801272
If Echo is right, it is a crazy mystery on how mine got to be so bent/curved. I've ordered a new one and will install when it gets here.
As usual, any input/advice is greatly appreciated.
Regards,
Theodore.
If you are talking about the plate that has the screw hole for the cover in it as per the photo then bending will be from overtightening and concavity will be from being bashed into something.
