Does this sound right?
The LAV30 was built in the 60's, it never had a blade brake. One of my favorites, properly tuned it would start with a quick flip of the rope. Maybe the blade was loose, it didn't sound like one was installed.
X 3 on the blade brake I do see one on the engine but I don't know if it's away from the flywheel ......
I don't see any cables to where a blade brake would be(left side from the operators point of view)... Just a throttle cable on the right side to the carb/governor.
As noted earlier, I don't believe they had blade brakes that early. And if it was activated, he wouldn't be able to pull it (if installed correctly)
Op, are you still around? Any updates, video's to share?
