Kubota B 4200 lost power
johnorlandi
Hi Guys need some help
I have a 1995 Kubota B4200 4 wheel drive with a 2 cylinder 12 HP diesel engine with 812 hours. It has been loosing power
Put a new fuel filter and no water in the fuel. Added diesel additive and let run for a while and no change
Got any ideas
Thank John O
cpurvis
Does it only have one fuel filter?
jp1961
Did you check to see if the valves are opening and closing by looking through the oil cap in the valve cover? I did hear of a Kubota engine pushing it's cam bearing out.
I did have the bolt holding the pulley/harmonic balancer on the front of the crank back out (although this was on a Yanmar 2 cylinder diesel).
Check the air filter? Did you bleed the fuel line after replacing the fuel filter?
Other than the above, there's not a whole lot you can check on a diesel. It's possible to have a bad injector pump or injector or low compression,,,hard to tell without taking it to a Kubota dealer.
Regards
Jeff
cpurvis
Yes only the one by the manual
Can you describe the problem in more detail?
About the only things that will cause a diesel to lose power is lack of fuel, something wrong with the injection $ystem, damage to valves or overheating. Most of the time, it is simply lack of fuel. That's not to say it can't be an internal engine problem but most of the time, it's a lack of fuel.
Did you bleed the fuel system after installing the new filter?
Are you the original owner or is there a chance someone else took it upon himself to install an inline pre-filter that you haven't noticed?
When it loses power, if you shut the engine off and restart, does the engine then run any better?
Does it have full power when you first start it (from a cold condition)?
What does the exhaust look like? Black smoke, no smoke, other? Smooth or irregular? If black, check your air filter.
Is the fuel gravity fed or does it have a fuel pump to feed the injection pump?
Any difference in the sound of the engine when it loses power?
I am not a diesel tech but I've owned my fair share of diesels, both tractors and trucks, over the years. Loss of power, in my case, has always been a fuel filter that needed replaced. If your engine was running OK and suddenly developed this problem, that would be where I would look first.
jp1961
I just Googled power loss on a small diesel and the one thing to add which hasn't already been mentioned is muffler plugged?
Regards
Jeff
cpurvis
Good point about the muffler.
jp1961, I didn't see your post above mine before I posted or mine would have been a lot shorter.
jekjr
Check your air filter. Many times they will stop up and cause air flow problems.
johnorlandi
Did you bleed the fuel system after installing the new filter? No I did not I filled the bowl. The problem was before the filter that is one of the reasons I changed the filter
Are you the original owner or is there a chance someone else took it upon himself to install an inline pre-filter that you haven't noticed? I am not the original owner and I looked around and did not see anything unusual.
When it loses power, if you shut the engine off and restart, does the engine then run any better?. The engine runs the same from start up to shut down
Does it have full power when you first start it (from a cold condition)? No the same all the time
What does the exhaust look like? Black smoke, no smoke, other? Smooth or irregular? If black, check your air filter. First start it is a little black and then just about none
Is the fuel gravity fed or does it have a fuel pump to feed the injection pump? I believe it is a fuel pump
Any difference in the sound of the engine when it loses power? The lost power is from is from start up
I am not a diesel tech but I've owned my fair share of diesels, both tractors and trucks, over the years. Loss of power, in my case, has always been a fuel filter that needed replaced. If your engine was running OK and suddenly developed this problem, that would be where I would look first. Correct that is why I changed the filter but I ran it yesterday and it seemed to run better after the additive may have cleaned something out not real good but it definetly was better.
I put a diesel additive in and ran it for a while with no change, yesterday I went out to get a load of fire wood and it seemed to run a little better where I had some power maybe not full but more. So maybe the injectors are dirty and this additive will clean them out I HOPE! the additive is Power Service, Diesel Kleen injector cleaner and performance improved. I HOPE THIS WORKS
thanks for your help and I will add to this in a few days THANK YOU did not know how to change color to the text or it would have looked better
Reply With Quote Reply With Quote Multi-Quote This Message .
Yesterday, 02:49 PM
#6
jp1961
jp1961 is online now
BlazNT
Can you explain your last comment please?
