MTD front wheel bushings
Ronno6
Who out there has replaced the plastic front wheel bearings on MTD tractors with oilite or super oilite bushings?
Like the 941-0990 and 941-0516 outside bush??
I hope those are the correct #'s,,,
For MTD 14AR808K731
I see parts listing for complete wheel/tire assy...gotta dig deeper..
How about something like this: https://www.mcmaster.com/5905k27
Would the lack of spindle hardening be a problem?
For MTD 14AR808K731
I almost always go to the hardware store and change bushings to brass.
Whacha think of needle bearings??
Needle rollers really should only be inside things that are fully enclosed.
A very small amount of dust can jamb the rollers then you have a steel on steel bearing.
Needle rollers are usually open and run direction on the shaft ( no inner race so the shafts need to be GROUND round and better than 75R hard.
Yeah, I kinda figgered the axle needed to be hardened........
Looks like I.m goin' bronze.
Thanks, Bert man!
Maybe I can figger a way to use a 3/4" x 8" shoulder bolt for the axle......
