(Account Closed)
- Dec 3, 2018
- 260
Working on a customers CS 355T chain saw that locked up.
Upon tear down, I found the crankshaft has TWO sets of plastic "parts" attached to the crankshaft. One set came off and locked up the engine. No other damage to the engine once the debris was removed.
The parts fisch, for a new crank does NOT show these plastic parts..
Masking tape is attached to remaining plastic part. The metal wire with loop ends hold the plastic parts to the crank..
I suspect I'll be removing the other and re-assembling (as a new crank doesn't have them).
I've never seen a two stroke with this part attached to the crank.
Any downsides removing them?
Anyone know what their for?
