Trcustoms719
- May 16, 2011
- 62
First replace the diaphragm. then you You need to stretch that spring a little at a time (see pic link below) that will make the engine idle down like you want.It finally stopped raining for a while...so...time to get the carb off...except it is this strange little plastic thing with a primer bulb that doesn't make sense compared to the mikumi carb I clean out on my regular mower...so I googled to see how to clean it and found that they don't need much cleaning and there isn't anything you can strip...BUT...the diaphragm gives problems...
I had to practically dismantle the mower to get the carb off (providing a learning opportunity in terms of coil gaps later :confused2: ) and found that there was a spare piece of old diaphragm somehow stuck in with the gasket (did not seem helpful) and the actual diaphragm had been torn off one of the screws, probably while fitting it. Not in a functional area, but it would definitely interfere with the seal and tension.
Invested 5 euros in a new diaphragm and gasket from ebay, and tried to seat the old one better to see if it helped, or even changed anything.
Had to mess around resetting the coil gap a bit...
...then nearly died when it finally sprung into life
No fluke, it is now starting on the first light pull reliably. I will replace the diaphragm because it will not hold long like that...but my only worry now is that the engine seems to be racing. It has a governor and idle spring, not screws...don't think it is the throttle because it won't shut down even at the lowest point manually...
Any ideas?
PS Only starts on first pull when warm...still troublesome to cold start at all.
http://i43.servimg.com/u/f43/15/73/00/59/briggs10.jpg
