What's the best thing to do with the fuel in the Cub over winter? I probably have 1 mowing left. Should I just let the carb run out of fuel? Should I add a additive of some sort, or just put fresh gas in it next spring?
It is pretty hard to buy gas in Michigan that is not 10% methanolIf you're running ethanol gas, drain it. If you're running ethanol-free gas, you don't need to do anything.
or ethanol whatever it is.It is pretty hard to buy gas in Michigan that is not 10% methanol
